    Quelle: https://www.woltlab.com/plugin…de-shop-8-0-discord-push/
    Quelle: https://www.woltlab.com/plugin…push-community-bot-cloud/
    Quelle: https://www.woltlab.com/plugin…de-shop-8-0-sevdesk-sync/
    Quelle: https://www.woltlab.com/plugin…53-dynamischer-tab-titel/
    • WoltLab Suite 5.4.14
    • WoltLab Suite 5.3.20
    How to Apply Updates
    Open your Administration Control Panel and navigate to “Configuration → Packages → List Packages”. Please click on the button “Search for Updates” located in the right corner above the package list.
    • The “Customers Who Bought This File Also Bought” box will only show up when there are at least two customers to protect the identity of the first buyer. 5.4
    • The importer for file versions will now skip any version that could not be associated with a file instead of raising an exception. 5.4
    • Notifications for removed labels will no longer trigger an error. 5.4
    • Invision Community 4.x
      • The import of threads with large gaps in the assigned IDs has been fixed. 5.4
      • Passwords using the BCrypt hash are now recognized and preserved. 5.4
    • The sort order of conversations that a user has been removed from was sometimes incorrect. 5.4
    • The list of conversations showed an incorrect value for the “Last Message” when the user was removed from this conversation before. The value now matches the actual value at the time of removal. 5.4 5.3
    • Formatting a word in the editor did not immediately mark the corresponding button as active. 5.4
    • Resolved a visual artifact on the list of notification settings. 5.4
    • The file size was displayed twice for uploaded media. 5.4
    • The restriction to view only own media files was not applied in all places. 5.4
    • Inserting or editing links in the editor stopped working in iOS 15. 5.4
    • Own settings for boxes are no longer overwritten during an upgrade. 5.4
    • Messages of blocked users are now automatically expanded when accessing them through a permalink. 5.4
    • Resolved a visual artifact of “altert” boxes (information / success / warning / error) in dialogs. 5.4
    • The phrase for HTML email notifications for replies to comments on articles was erroneous. 5.4
    • Invoking the cli.php using PHP 8.0 no longer yields a warning. 5.4
    • For developers: The PHP DDL API did not handle YEAR columns in MySQL 8 correctly. 5.4 5.3
    • For developers: The CheckboxFormField is now properly supported in AJAX forms. 5.4
    Quelle: https://www.woltlab.com/commun…tlab-suite-5-4-14-5-3-20/
    • Die „Kunden, die diese Datei gekauft haben, kauften auch“-Box wird jetzt nur angezeigt, wenn es mindestens zwei Käufer gibt, um die Privatsphäre des ersten Käufers besser zu schützen. 5.4
    • Der Importer von Dateiversionen überspringt jetzt Versionen die keiner Datei zugeordnet werden können, statt mit einer Fehlermeldung abzubrechen. 5.4
    • Moderationsbenachrichtigungen über entfernte Label führen nicht mehr zu einer Fehlermeldung. 5.4
      • Der Import von Themen mit großen Lücken in den IDs wurde korrigiert. 5.4
      • Kennwörter, die mit BCrypt gehasht wurden, werden jetzt beim Import übernommen. 5.4
    WoltLab Suite Core: Konversationen
    • Konversationen, aus denen man vom Ersteller der Konversation entfernt wurde, wurden unter Umständen in der Liste von Konversationen fehlerhaft einsortiert. 5.4
    • Bei Konversationen, aus denen man vom Ersteller der Konversation entfernt wurde, wurde unter Umständen in der Liste von Konversationen eine fehlerhafte „letzte Nachricht“ angezeigt. Jetzt erscheinen zuverlässig die Daten der letzten für den Teilnehmer sichtbaren Nachricht. 5.4 5.3
    • Nach dem Formatieren eines Wortes im Editor wurde der dazugehörige Button nicht unmittelbar als aktiv markiert. 5.4
    • Ein Darstellungsproblem in den Benachrichtigungseinstellungen wurde behoben. 5.4
    • Die Dateigröße wurde bei hochgeladenen Medien doppelt angezeigt. 5.4
    • Die Beschränkung des Zugriffs nur auf eigene Medien wurde nicht durchgehend korrekt angewendet. 5.4
    • Das Einfügen und Bearbeiten von Links im Editor funktionierte in iOS 15 nicht mehr. 5.4
    • Eigene Einstellungen für Boxen bleiben bei Upgrades jetzt korrekt erhalten. 5.4
    • Nachrichten blockierter Nutzer werden bei Verwendung eines Permalinks jetzt automatisch ausgeklappt. 5.4
    • Die Darstellung von „Alert“-Boxen (Information / Erfolg / Warnung / Fehler) in Dialogen wurde korrigiert. 5.4
    • Eine fehlerhafte Sprachvariable in der HTML-Variante von E-Mail-Benachrichtigungen für Kommentar-Antworten von Artikelkommentaren wurde korrigiert. 5.4
    • Der Aufruf der cli.php führt unter PHP 8.0 nicht mehr zu einer Warnung. 5.4
    • Für Entwickler: Die Synchronisierung von YEAR-Spalten mit der PHP DDL-API unter MySQL 8 wurde korrigiert. 5.4 5.3
    • Für Entwickler: Das CheckboxFormField funktioniert jetzt korrekt in AJAX-Formularen. 5.4
    Quelle: https://www.woltlab.com/pluginstore/file/7149-mountain/
    Quelle: https://www.woltlab.com/plugin…ngsdienstleisters-mollie/
    Quelle: https://www.woltlab.com/plugin…hop-8-0-stornorechnungen/
    Quelle: https://www.woltlab.com/plugin…konto-erstellen-formular/
    Quelle: https://www.woltlab.com/plugin…141-branding-free-winter/
    Quelle: https://www.woltlab.com/plugin…7139-branding-free-glive/
    Quelle: https://www.woltlab.com/plugin…7137-branding-free-pilot/
    Quelle: https://www.woltlab.com/plugin…135-branding-free-smooth/
    Quelle: https://www.woltlab.com/plugin…e/7133-instagram-galerie/
    Quelle: https://www.woltlab.com/commun…-13-5-3-19-5-2-19-3-1-27/
    Quelle: https://www.woltlab.com/plugin…/7129-disasters-blizzard/
