Design enthält sichtbares Copyright.
Geprüfte Browser(immer Aktuelle Version)
Google Chrome
Mozilla Firefox
Quelle: https://www.woltlab.com/pluginstore/file/7193-the-dark/
Google Chrome
Mozilla Firefox
- WoltLab Suite 5.4.16
- WoltLab Suite 5.3.22
How to Apply Updates
Open your Administration Control Panel and navigate to "Configuration > Packages > List Packages". Please click on the button "Search for Updates" located in the right corner above the package list.
- Deleting a blog containing articles now requires that you have the permission to delete articles. 5.4
- The permission to create articles is now correctly considered for user groups as co-authors. 5.4
- Menu items that link directly to a private forum now correctly show the number of unread topics. 5.4
- Editing pictures of different members at the same time no longer causes an error message. 5.4
- IP.Board 3.4.x
- Gallery import was fixed. 5.4
- Compatibility with MySQL 8 was fixed. 5.4
- vBulletin 3.x/4.x
- Forum sections are no longer imported incorrectly as categories. 5.4
- Incorrect redirection for links to inaccessible articles. 5.4
- When updating users, cover photos using the GIF format were not processed correctly. 5.4
- The alignment of embedded file attachments was not displayed correctly in some cases. 5.4
- Keyboard commands were interpreted incorrectly in nested dialogs. 5.4
- Very small file attachments were displayed distorted in the preview. 5.4
- Several improvements were made to the preprocessing of search terms for MySQL-based searches. 5.4
- The external guzzlehttp/psr7 library was updated to correct a bug in HTTP header validation. 5.4 5.3
- Updated favico.js to prevent an error when used with Firefox 100. 5.4
- The cache is now reset correctly after creating new language variables via the administration interface. 5.4
- A display error with empty code boxes has been corrected. 5.4
- For developers: The PHP-DDL-API now rejects ->defaultValue() values for BLOB and TEXT columns, because they are not supported in older MySQL versions and only inconsistently between MySQL and MariaDB in newer versions. Additionally this pull request should be considered: https://github.com/WoltLab/WCF/pull/4733 5.4
Quelle: https://www.woltlab.com/commun…tlab-suite-5-4-16-5-3-22/
- Die Löschung eines Blogs mit Artikeln ist jetzt nur noch möglich, wenn man die Berechtigung zum Löschen von Artikeln hat. 5.4
- Die Berechtigung zum Erstellen von Artikeln wird jetzt auch für Benutzergruppen als Co-Autor korrekt berücksichtigt. 5.4
- Menüpunkte die direkt auf ein privates Forum verweisen zeigen jetzt korrekt die Anzahl der ungelesenen Themen. 5.4
- Das gleichzeitige Bearbeiten von Bildern unterschiedlicher Mitglieder führt nicht mehr zu einer Fehlermeldung. 5.4
- IP.Board 3.4.x
- Der Galerie-Import wurde korrigiert. 5.4
- Die Kompatibilität mit MySQL 8 wurde korrigiert. 5.4
- vBulletin 3.x/4.x
- Forenbereiche werden nicht mehr fehlerhaft als Kategorien importiert. 5.4
- Fehlerhafte Umleitung bei Links zu unzugänglichen Artikeln. 5.4
- Bei der Aktualisierung von Benutzern wurden Titelbilder im GIF-Format nicht korrekt verarbeitet. 5.4
- Die Ausrichtung von eingebetteten Dateianhängen wurde in einigen Fällen nicht richtig dargestellt. 5.4
- Bei verschachtelten Dialogen wurden Tastatur-Befehle fehlerhaft interpretiert. 5.4
- Sehr kleine Dateianhänge wurden in der Vorschau verzerrt dargestellt. 5.4
- Es wurden mehrere Verbesserungen an der Vorverarbeitung von Suchbegriffen für die MySQL-basierte Suche vorgenommen. 5.4
- Die externe guzzlehttp/psr7-Bibliothek wurde aktualisiert, um einen Fehler bei der Validierung von HTTP-Headern zu korrigieren. 5.4 5.3
- Anpassung von favico.js zur Vermeidung eines Fehler beim Einsatz unter Firefox 100. 5.4
- Der Cache wird jetzt nach dem Anlegen neuer Sprachvariablen über die Administrationsoberfläche korrekt zurückgesetzt. 5.4
- Ein Darstellungsfehler bei leeren Code-Boxen wurde korrigiert. 5.4
- Für Entwickler: Die PHP-DDL-API lehnt ->defaultValue()-Werte für BLOB und TEXT-Spalten jetzt ab, da diese in älteren MySQL-Versionen nicht und in neueren Versionen nur inkonsistent zwischen MySQL und MariaDB unterstützt werden. Ergänzend sollte auch dieser Pull Request beachtet werden: https://github.com/WoltLab/WCF/pull/4733 5.4
Alles anzeigenDieses Plugin integriert Google One Tap in WoltLab, welches das Registrieren mit wenigen Klicks und ohne Eingaben von Daten erlaubt. Zusätzlich werden registrierte Benutzer automatisch oder mit nur einem Klick angemeldet. Die einzige Voraussetzung hierfür ist, dass der Benutzer in Google angemeldet ist.
Wenn der Benutzer nicht in Google angemeldet ist, wird bei der Anmeldung auf den Passwort-Manager des Browsers zurückgefallen, solange die Credential Manager API vom Browser unterstützt wird.
- Erhöhte Registrierübungsrate
- Vereinfachte Registrierung und Anmeldung
- Automatisches Anmelden mit Google Accounts und mit gespeicherten Benutzerkonten vom Browser Passwort Manager
- Bietet bestmögliche Kompatibilität durch das Erweitern der existierenden Google Authentifizierung von WoltLab
Fallstudien
Wir haben das Plugin selbst seit einer langen Zeit in Verwendung und haben eine sehr erhöhte Registrierübungsrate festgestellt.
Unterhalab sind Statistiken von der Veränderung an Benutzern insgesamt und davon die Anzahl an Google Benutzern.
Wie zu sehen ist, erhöht sich die Anzahl an neuen Benutzern (Gelbe Linie) durch die Google Registrierungen (Blaue Linie) deutlich.
Weitere Fallstudien sind hier zu finden: https://developers.google.com/identity/sign-in/case-studies
Weitere Funktionen und Wissenswertes
- Bei dem Mobile Layout von Google One Tap wird der Cookie Hinweis unter den Seitentitel verschoben, damit dieser nicht überdeckt wird.
- Auf der Registrierungsseite wird optional ein Hinweis angezeigt, wenn bereits ein Benutzer mit der gleichen IP registriert ist. (Vermeidet unabsichtliche doppelte Registrierungen).
- Google One Tap wird für Gäste auf allen Seiten angezeigt, die indexiert werden dürfen und auf der fehlende Berechtigungsseite.
Installation
Nachdem das Plugin installiert wurde, muss unter Konfiguration -> Benutzer -> Registierung -> Authentifizierung über Drittanbieter "Google Client ID" und "Google Client Secret" ausgefüllt werden. Wenn hier bereits eine ID eingetragen ist, sollte überprüft werden ob der OAuth-Zustimmungsbildschirm dafür konfiguriert ist. Damit ist das Plugin bereits aktiviert und verwendbar. Um sicherzustellen, dass der OAuth richtig eingestellt wurde, sollte das registrieren über Google One Tap ein mal getestet werden.
Eine Anleitung zum erstellen der benötigten Informationen und zum konfigurieren des OAuth-Zustimmungsbildschirm ist hier zu finden: https://developers.google.com/…s/get-google-api-clientid
Deinstallation
Das Plugin speichert keine zusätzlichen Daten und Benutzer, die sich über Google One Tap registriert haben, können sich einfach manuell durch die Google Authentifizierung von WoltLab anmelden. Das deinstallieren verhindert daher nicht, dass sich die Benutzer nicht mehr anmelden können.
Datenschutzhinweis
Es wird für Gäste auf allen Seiten der Google API JavaScript Client über https://accounts.google.com/gsi/client geladen.
Quelle: https://www.woltlab.com/plugin…file/7191-google-one-tap/
Alles anzeigenHinweise zu diesem Plugin
- Es kann konfiguriert werden, wie viele paysafecard-PINs eingegeben werden können. Damit kann optional die Kombination mehrerer paysafecard-PINs ermöglicht werden.
- Dieses Plugin verwendet keine externe API, um die vom Käufer eingegebenen paysafecard-PINs zu validieren oder zu verarbeiten. Daher ändert sich der Status der Bestellung nach Eingabe der paysafecard-PINs von „Warte auf Zahlung“ zu „Zahlung in Verarbeitung“. Dabei wird die Bestellung noch nicht freigeschaltet! Das bedeutet, dass ein Administrator die Bestellung im ACP zuerst prüfen, die paysafecard-PINs verarbeiten und dann die Bestellung manuell freischalten muss, damit der Käufer sein erworbenes Produkt erhält.
Voraussetzungen
- Sie müssen WoltLab Suite™ Core 5.4 installiert haben.
- Sie müssen VieCode Shop 8.0 installiert haben.
WoltLab Cloud
Datei
VieCode Shop (WoltLab Suite)
Das ultimative Shop-System für die WoltLab Suite
Vor 21 Minuten
Installation und Ersteinrichtung
Sie können dieses Plugin ganz normal installieren und analog zu den Einstellungen der Zahlungsanbindungen von VieCode konfigurieren.
Nach dem Kauf im Plugin-Store von WoltLab
Sie können sich bei Krymo Software registrieren und Ihr erstelltes Benutzerkonto mit Ihrem WoltLab-Konto verknüpfen, sodass Ihnen dort innerhalb weniger Minuten automatisch Zugriff auf den Produktsupport gewährt wird.
Quelle: https://www.woltlab.com/plugin…rd-manuelle-verarbeitung/
Alles anzeigenDieses Plugin erinnert Mitglieder, die im VieCode Shop eine Mitgliedschaft gekauft haben, daran, diese vor dem auslaufen zu verlängern.
Benötigt werden folgende Plugins:
WoltLab Cloud
Datei
Montag, 17:23
WoltLab Cloud
Datei
VieCode Shop: Bezahlte Mitgliedschaften
Ermöglicht den Verkauf von Premiummitgliedschaften im VieCode Shop
28. Februar 2022
Quelle: https://www.woltlab.com/plugin…itgliedschaft-erinnerung/
Alles anzeigenWe have just released new versions of our products:
- WoltLab Suite 5.4.15
- WoltLab Suite 5.3.21
- WoltLab Suite 5.2.20
- WoltLab Suite 3.1.28
Security Notice
It has been brought to our attention that in the log of cronjobs, there may be an unintended execution of HTML in case of an error. This can occur if, for example, a cronjob retrieves data from an HTML page and, in the event of an error, stores HTML code as an error message. To our knowledge, this vulnerability cannot be deliberately exploited by an attacker. Many thanks to @SoftCreatR for bringing this issue to our attention.
We have also received reports that a so-called "Self-XSS" attack can occur when uploading file attachments with specially crafted file names. This can only be exploited when running Linux and macOS, Windows does not allow the special characters in the filename. The impact is limited to the user themselves at the time of upload, there is no further impact. This vulnerability can never be exploited to attack other users or visitors of the site.
All WoltLab Cloud customers have already been patched to address these issues
- When switching to another month, the filter by label was discarded. 5.4
- Label groups could be set only for the first levels of categories. 5.4
- An incorrect message was generated when accessing a file that does not exist. 5.4 5.3
- Deactivated versions can now be viewed by the ”other authors” of a file. 5.4
- Creating direct links to a filtered list of topics could generate invalid links in rare cases. 5.4
- vBulletin 5.x
- The import of Argon2 passwords has been corrected.
- (SECURITY): HTML in the error message of failed cronjobs is now correctly masked in the cronjob log. 5.4 5.3 5.2 3.1
- (SECURITY): HTML is now correctly masked in the filename display while uploading a file attachment. After the upload is finished and when editing a content (e.g. post) the behavior was already correct. 5.4 5.3 5.2 3.1
- Mentioning user groups with non-Latin letters was corrected. 5.4
- The implicit expansion of content from blocked users when accessing them via a direct link, introduced in WoltLab Suite 5.4.14, was reverted because it had too many unwanted side effects and caused confusion among users. 5.4
- Links inserted into the editor on iOS and Android no longer end up at the start of the text. 5.4
- Fixed IPv4 address detection with the StopForumSpam integration. 5.4 5.3
- Empty user profile fields of labeledUrl type are no longer displayed in the profile. 5.4
- Fixed processing of search terms in quotes when using the MySQL-based search. 5.4
- The rich embeds now ignore all non-HTTP links instead of trying to retrieve them unsuccessfully. 5.4
- Unknown encodings of the retrieved web page no longer cause the rich embeds to log an error message. 5.4
- Improved the user experience when selecting objects (e.g. a forum section) to configure a menu item. 5.4
- Marking quotable text on Android / Chrome Mobile no longer causes the entire page to be marked when hovering over the quote menu. 5.4
- When submitting a form with Incorrect values entered, the correct tab was not opened automatically. 5.4
- Searching in profile fields with decimal numbers now normalizes the user‘s localized search input. 5.4
- Invalid input error message for profile fields for integers has been improved. 5.4
- Consideration of words shorter than the minimum length for inclusion in the MySQL search index is no longer forced. Without this change the search results were filtered out in which the words occur alone and only results were returned in which these words appear as part of a word. 5.4
- For developers: Bug fixes to the dev tools. 5.4
- For developers: Disabled input fields for date selection were not initialized correctly. 5.4
- For developers: The escape key in dialogs now triggers the callback for onBeforeClose. 5.4
- For developers: Error handling for incorrect $limit and $offset parameters in ->prepare() and ->prepareStatement() has been improved. 5.4 5.3
Quelle: https://www.woltlab.com/commun…-15-5-3-21-5-2-20-3-1-28/
Alles anzeigenWir haben soeben Updates für unsere Produkte freigegeben:
Sicherheitshinweis
Wir wurden darauf aufmerksam gemacht, dass es im Protokoll von Cronjobs im Falle eines Fehlers zu einer ungewollten Ausführung von HTML kommen kann. Dies kann dann auftreten, wenn ein Cronjob beispielsweise Daten von einer HTML-Seite abruft und im Fehlerfall beispielsweise HTML-Code als Fehlermeldung ablegt. Diese Schwachstelle lässt sich unseren Erkenntnis nach nicht gezielt durch einen Angreifer ausnutzen. Vielen Dank an dieser Stelle an @SoftCreatR, der uns auf dieses Problem aufmerksam gemacht hat.
Ebenfalls wurde uns gemeldet, dass es beim Hochladen von Dateianhängen mit speziell präparierten Dateinamen zu einem sogenannten „Self-XSS“-Angriff kommen kann. Dies lässt sich ausschließlich unter Linux und macOS ausnutzen, Windows erlaubt die dafür notwendigen Zeichen im Dateinamen grundsätzlich nicht. Die Auswirkung ist auf den Benutzer selbst zum Zeitpunkt des Hochladens begrenzt, weitere Auswirkungen hat dies nicht. Diese Schwachstelle kann grundsätzlich nicht für einen Angriff auf andere Benutzer oder Besucher der Seite ausgenutzt werden.
Alle Installationen von WoltLab Cloud-Kunden wurden bereits aktualisiert.
- Beim Wechsel auf einen anderen Monat wurde der Filter nach Labels verworfen. 5.4
- Label-Gruppen konnten irrtümlich nur für die ersten Ebenen von Kategorien eingestellt werden. 5.4
- Beim Aufruf einer nicht existierenden Datei wurde eine fehlerhafte Meldung erzeugt. 5.4 5.3
- Deaktivierte Versionen können jetzt auch von den „weiteren Autoren“ einer Datei eingesehen werden. 5.4
- Die Erzeugung von Direktlinks auf eine gefilterte Themenliste konnte in seltenen Fällen ungültige Links erzeugen. 5.4
- vBulletin 5.x
- Der Import von Argon2-Kennwörtern wurde korrigiert.
- (SICHERHEIT): HTML in der Fehlermeldung von fehlgeschlagenen Cronjobs wird im Cronjob-Protokoll jetzt korrekt maskiert. 5.4 5.3 5.2 3.1
- (SICHERHEIT): HTML wird in der Anzeige des Dateinamen während des Uploads eines Dateianhangs jetzt korrekt maskiert. Nach Abschluss des Uploads und beim Editieren eines Inhalts (bspw. Beitrags) war das Verhalten bereits korrekt. 5.4 5.3 5.2 3.1
- Das Erwähnen von Benutzergruppen mit nicht-lateinischen Buchstaben wurde korrigiert. 5.4
- Das automatische Ausklappen von blockierten Inhalten bei einem Direktlink in WoltLab Suite 5.4.14 wurde rückgängig gemacht, da es unerwartete Auswirkungen auf die Benutzererfahrung hatte. 5.4
- In den Editor eingefügte Links unter iOS und Android landen nicht mehr am Textanfang. 5.4
- Die Erkennung von IPv4-Adressen mit der StopForumSpam-Integration wurde korrigiert. 5.4 5.3
- Leere Benutzerprofilfelder vom Typ labeledUrl werden nicht mehr im Profil angezeigt. 5.4
- Die Verarbeitung von Suchbegriffen in Anführungszeichen wurde bei Verwendung der MySQL-basierten Suche korrigiert. 5.4
- Die Rich Embeds ignorieren jetzt alle nicht-HTTP-Links, anstatt zu versuchen diese erfolglos abzurufen. 5.4
- Unbekannte Kodierungen der abgerufenen Webseite führen bei den Rich Embeds nicht mehr dazu, dass eine Fehlermeldung geloggt wird. 5.4
- Die Benutzererfahrung bei der Auswahl von Objekten (bspw. eines Forenbereichs) zur Konfiguration eines Menüpunktes wurde verbessert. 5.4
- Die Markierung von zitierbaren Texten führt unter Android / Chrome Mobile beim Überfahren des Zitiermenüs nicht mehr dazu, dass die ganze Seite markiert wird. 5.4
- Beim Absenden eines Formulars mit fehlerhaften Eingaben wurde der richtige Tab nicht automatisch geöffnet. 5.4
- Die Suche in Profilfeldern mit Dezimalzahlen normalisiert jetzt die lokalisierte Such-Eingabe des Benutzers. 5.4
- Die Fehlermeldung bei ungültigen Eingaben für Profilfelder für Ganzzahlen wurde verbessert. 5.4
- Die Berücksichtigung von Wörtern, die kürzer als die minimale Länge zur Aufnahme in den MySQL-Suchindex sind, wird nicht mehr erzwungen. Ohne diese Änderung wurden die Suchergebnisse ausgefiltert, in denen die Wörter alleinstehend vorkommen und lediglich Ergebnisse zurückgeliefert, in denen diese Wörter als Wortbestandteil auftauchen. 5.4
- Für Entwickler: Fehlerkorrekturen an den Dev Tools. 5.4
- Für Entwickler: Deaktivierte Eingabefelder für die Datumsauswahl wurden nicht korrekt initialisiert. 5.4
- Für Entwickler: Der Escape-Key in Dialogen löst nun den Callback für onBeforeClose aus. 5.4
- Für Entwickler: Die Fehlerbehandlung für fehlerhafte $limit und $offset-Parameter in ->prepare() und ->prepareStatement() wurde verbessert. 5.4 5.3
Alles anzeigenDas Plugin bringt euch eine einfach Box in eure Sidebar der Suite,
wo die Online User eures Discord Servers angezeigt werden.
Im ACP müsst ihr den Widget Link von eurem Server eintragen. Einfach raus kopieren.
Dann im ACP eintragen.
Zusätzlich könnt ihr noch euer Server Bild anzeigen lassen. Das könnt ihr euch über die Konsole des Browser rauskopieren.
Quelle: Discord User online
Eigenschaften
- Erstklassiges, modernes Design
- Dunkle Hintergründe
- Leicht anpassbare Farben
- Kompatibel mit allen offiziellen WoltLab-Erweiterungen
- Spezielle Info- und Bildboxen für ein individuelles Erlebnis (Anleitung weiter unten)
Zusätzliche Boxen/Features
Flexible Bilderliste mit Verlinkung: Ideal für Portfolios und Produktvorstellung
Wie wird die Box angelegt?
- Gehe zu Kontrollzentrum > Administration > Boxen > + Box hinzufügen > Box-Typ "HTML"
- Allgemeine Daten: Name der Box eintragen, Boxposition sowie Verlinkung festlegen
- Inhalte: Den folgenden Beispiel-Quellcode in den Inhaltsbereich kopieren und den Teil <div>...</div> beliebig oft wiederholen
Code
Dieser BBCode ist nur für Mitglieder sichtbar! - Um den BBCode nutzen zu können Loggen Sie sich bitte ein oder Registrieren Sie sich.Alles anzeigen
- Verlinkung eintragen: Finde <a href="https://www.bliqpunkt.de/"> und ersetze https://www.bliqpunkt.de/ mit dem gewünschten Link
- Bild einfügen: Finde {{ media="84" size="original" }} und ersetze "84"mit der ID einer eigenen Mediendatei (oder Bild-URL)
Informationen mit Buttons, Icons, Bildern und Verlinkungen präsentieren
Mit dem "bliqpunkt Info Box"-Container können u.a. für Apps Kurzbeschreibungen mit passenden Icons verfasst werden. Mittels der Buttons kann der User zum jeweiligen Downloadbereich für die Apps gelangen. Durch einen Screenshot auf der rechten Seite bekommt der User nochmal einen Überblick. Auch dieser Box-Container eignet sich bestens für Produkt- und Dienstleistungspräsentationen sowie Werbung/Eigenwerbung.
- Allgemeine Daten: Name der Box eintragen, Boxposition, CSS-Klasse sowie Verlinkung festlegen
Code
- Überschrift eintragen: Finde <h1>bliqpunkt Info Box</h1> und ersetze bliqpunkt Info Box mit der gewünschten Überschrift
- Aufzählung mit Icons:
- Finde <span class="icon icon32 fa-bolt"></span> und ersetze fa-bolt mit dem Namen des ausgewählten Icons
- Finde <span class="listItemTitle">Labore et dolore magna</span> und ersetze Labore et dolore magna mit einem beliebigen Text
- Buttons
- Mit Icons und Verlinkung:
- Finde <a class="button buttonPrimary" href="https://www.bliqpunkt.de/"> und ersetze https://www.bliqpunkt.de/ mit dem gewünschten Link
- Neben dem geschlossenen Tag wird ein beliebiger Text eingetragen
- Finde <span class="icon icon32 fa-apple"></span> und ersetze fa-apple mit dem Namen des ausgewählten Icons
- Ohne Icons, nur Verlinkung:
- Finde <a class="button" href="https://www.bliqpunkt.de/"> und ersetze https://www.bliqpunkt.de/ mit dem gewünschten Link
- Text mit Verlinkung: Finde <p>Et ea rebum <a href="https://www.bliqpunkt.de/"</p> und ersetze den Text mit einem beliebig anderen sowie den Link href="https://www.bliqpunkt.de/"
- Bild: Finde <div class="imageContainer"> <img src="{{ media="93" size="medium" }}" /> </div> und ersetze "93"mit der ID einer eigenen Mediendatei (oder Bild-URL)
_________________________________________________________
Bilder sind Beispielinhalte und nicht im Stil enthalten!
Quelle: https://www.woltlab.com/plugin…e/7183-disasters-tsunami/
Auf Grund eines Fehlers im Update von der Version 7.2.x wurde unabsichtlich das Rechnungsnummernsystem umgestellt. Das hat zur Folge, dass die erste Rechnung, die in der Version 8.0 ausgestellt wird, wieder mit R22-000001 beginnt. Das hat neben Auswirkungen auf die Buchhaltung auch Auswirkungen auf die Funktionsweise vom Shop, da es u.U. vorkommen kann, dass Rechnungsnummern doppelt verwendet werden. Dies wird zwar vom Shop aktiv verhindert, führt aber dazu, dass keine neuen Rechnungen ausgestellt werden. Von diesem Fehler sind nur Kunden betroffen, die von Version 7.2 aktualisiert haben und die Standardeinstellung zur Generierung von Rechnungsnummern verwendet. Dieses Plugin ermöglicht es betroffenen Kunden ermöglicht die fehlerhaft ausgestellten Rechnungen zu korrigieren.
Das Plugin erkennt automatisch, ob die Installation von dem Fehler betroffen ist. Fehlerhaft ausgestellte Rechnungen werden vor der Korrektur aufgelistet und müssen aktiv bestätigt werden. Bitte überprüfen Sie unbedingt, ob die aufgelisteten Bestellungen betroffen sind und keine betroffene Rechnung fehlt. Anschließend kann die Korrektur durchgeführt werden. Dieser Schritt kann nur ein einziges mal durchgeführt werden und kann nicht rückgängig gemacht werden. Nach der Konvertierung kann der Betreiber entsprechende Stornorechnungen herunterladen. Kunden werden nicht automatisch informiert. Nach der Konvertierung und dem Herunterladen der Stornorechnungen kann das Plugin wieder deinstalliert werden.
Quelle: https://www.woltlab.com/plugin…echnungsnummernkonverter/
Einfache Erstellung eines QR-Codes
Mithilfe dieses BBCode können Sie spielend leicht einen QR-Code erstellen. Nutzen Sie folgenden BBCode zur Erstellung:
Code
Abhängigkeit
Diese Erweiterung benötigt folgendes (auch hier erhältliches) Entwicklerpaket:
WoltLab Cloud
Datei
"PHP-QR Code" - Bibliothek
Stellt die Bibliothek "PHP-QR Code" im WSC zur Verfügung.
7. Februar 2022
Bugs & Support
- Ticketsupport: https://my.d1strict.de/support/
- E-Mail: development@d1strict.net
Paketbezeichner: de.d1strict.wsc.plugin.qr-code-bbcode
Quelle: https://www.woltlab.com/plugin…file/7179-bbcode-qr-code/
Alles anzeigenMit der Branding Free – Lizenz ist es Ihnen gestattet, den sichtbaren Copyright-Hinweis aus dem „ACP-Stil“ zu entfernen.
Datei
ACP-Stil
Ein neues Aussehen für die Administration.
7. März 2022
Bugs & Support
- E-Mail: development@d1strict.de
Paketbezeichner: de.d1strict.wsc.brandingfree.acp-style
Quelle: https://www.woltlab.com/plugin…7-branding-free-acp-stil/
WICHTIG: Dieses Plugin benötigt eine vorhandene VieCode Filebase Lizenz!
Quelle: https://www.woltlab.com/plugin…de-filebase-brandingfree/
Verleiht der Administration ein neues Aussehen...
Nicht nur Ihre Benutzer sollen eine gut aussehende Weboberfläche sehen. Auch Sie – als Administrator – welcher möglicherweise täglich mit der Administration arbeiten muss, soll ein modernes Design „unter der Haube“ zu sehen bekommen.
Bugs & Support
Dieses Produkt enthält ein Branding, welches nur mit gültiger Branding Free - Lizenz entfernt werden darf.
Paketbezeichner: de.d1strict.wsc.style.acp
Quelle: https://www.woltlab.com/pluginstore/file/7169-acp-stil/
Quelle: TS3 Übersicht
Quelle: TS3 Viewer Sidebar
Alles anzeigenTeamspeak³ Viewer
Mit diesem Plugin erhalten Sie einen Teamspeak³-Viewer.
Damit ist es möglich, diverse Serverinformationen, sowie die aktuellen Clients in Ihrem WSC anzeigen zu lassen.
Mögliche Einstellungen
Im ACP können Sie den Teamspeak³ Viewer ganz nach Ihren Wünschen anpassen.
Unter Konfiguration - Optionen - Teamspeak3Viewer können Sie den Aktualisierungsintervall bestimmen.
Unter Benutzer - Benutzergruppen - Benutzergruppe bearbeiten - CMS können Sie selbst entscheiden, welche Benutzergruppen den Teamspeak³ Viewer sehen dürfen und welche nicht.
Willkommensnachricht
Die Serverseitige Willkommensnachricht wird angezeigt.
Es wird noch nicht der Hostbanner automatisch angezeigt dafür kann aber eine Grafik eingesetzt werden.
Unterstützte Versionen:
- WoltLab Suite™ Core 5.2
- WoltLab Suite™ Core 5.3
- WoltLab Suite™ Core 5.4
Getestete PHP Versionen:
- php 7.4
- php 8.0
- php 8.1
BitPay ist ein auf Kryptowährungen spezialisierter Zahlungsdienstleister, der seit 2011 mehr als 5 Milliarden USD und über 10 Millionen Transaktionen verarbeitet hat. Tausende Unternehmen vertrauen bereits BitPay, darunter auch Microsoft, Twitch, Namecheap, airBaltic und Newegg.
Welche Kryptowährungen und Stablecoins werden derzeit von diesem Plugin unterstützt?
- Bitcoin Cash (BCH)
- Bitcoin (BTC)
- Dogecoin (DOGE)
- Ethereum (ETH)
- Litecoin (LTC)
- Ripple (XRP)
- Shiba Inu (SHIB)
- Binance USD (BUSD)
- Dai (DAI)
- Gemini Dollar (GUSD)
- Paxos Standard (PAX)
- USD Coin (USDC)
- Wrapped Bitcoin (WBTC)
Andere, hier nicht aufgeführte Kryptowährungen und Stablecoins werden derzeit nicht unterstützt.
Wie kann ich anfangen, Zahlungen zu akzeptieren?
Sie müssen sich bei BitPay registrieren und dann die Anweisungen befolgen. Wir empfehlen Ihnen, zunächst diesen Prozess zu durchlaufen und erst danach dieses Plugin zu erwerben.
- Wiederkehende Zahlungen, wie es z. B. bei Kreditkarten mit automatischer Belastung der Fall ist, werden aufgrund der Natur von Kryptowährungen nicht unterstützt. Selbstverständlich sind wiederkehrende Zahlungen, bei denen der Kunde manuell einen neuen Zahlungsprozess auslöst, dennoch möglich.
- Je nach Konfiguration der Transaktionsgeschwindigkeit, die Sie in Ihren BitPay-Kontoeinstellungen vornehmen können, kann die Verifizierung einer Zahlung mehrere Minuten oder Stunden andauern. Diese Verzögerung ist nicht dem Plugin geschuldet, sondern dient der Sicherheit von Transaktionen.
Voraussetzungen
- Sie müssen über ein aktiviertes BitPay-Konto verfügen.
- Sie müssen PHP 7.1 oder neuer verwenden.
- Für PHP muss auf Ihrem Webserver OpenSSL verfügbar sein. Dies dürfte in der Regel bereits der Fall sein. Sollten Sie sich dennoch absichern wollen, können Sie das verlinkte Skript auf Ihrem Webserver hochladen und im Browser aufrufen.
WoltLab Cloud
Datei
Vor 23 Stunden
Sie können dieses Plugin ganz normal installieren und analog zu den Einstellungen der Zahlungsanbindungen von VieCode konfigurieren. Bei der Ersteinrichtung empfiehlt es sich, den Shop auf den Testmodus zu stellen und in den Einstellungen dieses Plugins Ihren Test-API-Schlüssel von BitPay zu hinterlegen sowie den Testmodus für BitPay zu aktivieren. Versuchen Sie nun, eine Bestellung in Ihrem Shop auszulösen und diese mittels einer der Kryptowährungen oder Stablecoins zu bezahlen. Warten sie einige Minuten und prüfen Sie danach, ob der Status der Bestellung korrekt aktualisiert wurde. Ist dies der Fall, können Sie in den Einstellungen des Plugins Ihren Live-API-Schlüssel hinterlegen, den Testmodus für BitPay deaktivieren und den Shop wieder auf den Produktivmodus stellen.
Quelle: https://www.woltlab.com/plugin…ngsdienstleisters-bitpay/
Neue Produkte
Erstellen Sie wie gewohnt neue Produkte in Ihrem Admin Control Panel. Nach der Aktivierung Ihres Produkts, wird automatisch eine Nachricht an Ihren Discord-Server gesendet.
Neue Versionen
In der Software-Entwicklung werden regelmäßig neue Versionen veröffentlicht. Leider bekommt nicht immer jeder Kunde direkt mit, dass es eine neue Version gibt. Deshalb wird bei der Veröffentlichung neuer Versionen automatisch eine Nachricht auf Ihren Discord-Server abgesetzt.
Neuer Lagerbestand
Hin und wieder kommt es vor, dass Versandwaren ausverkauft sind. In der Regel aktualisieren Sie dann Ihren Lagerbestand im Admin Control Panel. Wenn der Lagerbestand von 0 auf einen höheren Wert gesetzt wird, wird automatisch eine Nachricht an Ihren Discord-Server gesendet und ihre Kunden werden informiert, dass das Produkt wieder erhältlich ist.
Embed Farbe wählbar
Erstmalig kann bei einem Discord-Push-Plugin aus dem Hause Hanashi Development die Farbe des linken Rands des Embeds über einen Farbpicker festgelegt werden. Somit können Sie sich von anderen Discord-Servern abheben und sind nicht mehr auf die generische Standfarbe eingeschränkt.
Button
Unter jeder Nachricht wird automatisch ein Button erstellt. Je nach Preis wird dieser automatisch mit "Jetzt Kaufen" oder "Jetzt Herunterladen" beschriftet. Beim Klick auf diesen Button wird die Produktseite im Browser aufgerufen.
Automatische Veröffentlichung
Wenn Ihre Discord-Nachrichten in einem Ankündigungskanal geschrieben werden, werden diese automatisch veröffentlicht. Dadurch wird jeder Follower dieses Kanals direkt informiert und Sie müssen die Nachrichten nicht manuell veröffentlichen.
Konfiguration
Es gibt 2 Möglichkeiten dieses Plugin zu konfigurieren:
- Globale Konfiguration: ACP → Konfiguration → Shop → Discord-Push
- Kategoriebezogene Konfiguration: ACP → Shop → Kategorien → Kategorie auswählen
Voraussetzungen
Folgende Pakete sind Voraussetzungen:
- der VieCode Shop wird mindestens in Version 8.0.1 benötigt
- die WoltLab Suite wird mindestens in Version 5.4.14 benötigt
- Discord-API wird mintestens in Version 2.1.0 benötigt
Support
Support gibt es meinem Supportforum oder auf meinem Discord server.
Wie geht es nach dem Kauf weiter?
Quelle: https://www.woltlab.com/plugin…de-shop-8-0-discord-push/
