Verwenden Sie diese Dateien
Use these files
Code: userListItem
<li data-object-id="{@$user->userID}">
<div class="box48">
{user object=$user type='avatar48' ariaHidden='true' tabindex='-1'}
<div class="userListItemBackground" style="background-image: url({@$user->getCoverPhoto()->getURL()});"></div>
<div class="details userInformation">
{include file='userInformation'}
</div>
</div>
</li>
Smarty: usersOnlineList
{capture assign='pageTitle'}{$__wcf->getActivePage()->getTitle()}{if $pageNo > 1} - {lang}wcf.page.pageNo{/lang}{/if}{/capture}
{capture assign='headContent'}
<link rel="canonical" href="{link controller='UsersOnlineList'}{if $pageNo > 1}pageNo={@$pageNo}{/if}{/link}">
{if USERS_ONLINE_PAGE_REFRESH > 0}
<meta http-equiv="refresh" content="{@USERS_ONLINE_PAGE_REFRESH}; url={link controller='UsersOnlineList'}{if $pageNo > 1}pageNo={@$pageNo}&{/if}sortField={@$sortField}&sortOrder={@$sortOrder}{/link}">
{/if}
{/capture}
{capture assign='sidebarRight'}
<section class="box" data-static-box-identifier="com.woltlab.wcf.UsersOnlineListSorting">
<form method="post" action="{link controller='UsersOnlineList'}{/link}">
<h2 class="boxTitle">{lang}wcf.user.members.sort{/lang}</h2>
<div class="boxContent">
<dl>
<dt></dt>
<dd>
<select id="sortField" name="sortField">
<option value="username"{if $sortField == 'username'} selected{/if}>{lang}wcf.user.username{/lang}</option>
<option value="lastActivityTime"{if $sortField == 'lastActivityTime'} selected{/if}>{lang}wcf.user.usersOnline.lastActivity{/lang}</option>
<option value="requestURI"{if $sortField == 'requestURI'} selected{/if}>{lang}wcf.user.usersOnline.location{/lang}</option>
{if $__wcf->session->getPermission('admin.user.canViewIpAddress')}
<option value="ipAddress"{if $sortField == 'ipAddress'} selected{/if}>{lang}wcf.user.usersOnline.ipAddress{/lang}</option>
<option value="userAgent"{if $sortField == 'userAgent'} selected{/if}>{lang}wcf.user.usersOnline.userAgent{/lang}</option>
{/if}
</select>
<select name="sortOrder">
<option value="ASC"{if $sortOrder == 'ASC'} selected{/if}>{lang}wcf.global.sortOrder.ascending{/lang}</option>
<option value="DESC"{if $sortOrder == 'DESC'} selected{/if}>{lang}wcf.global.sortOrder.descending{/lang}</option>
</select>
</dd>
</dl>
<div class="formSubmit">
<input type="submit" value="{lang}wcf.global.button.submit{/lang}" accesskey="s">
</div>
</div>
</form>
</section>
<section class="box" data-static-box-identifier="com.woltlab.wcf.UsersOnlineListInfo">
<h2 class="boxTitle">{lang}wcf.user.usersOnline{/lang}</h2>
<p>{lang usersOnlineList=$objects}wcf.user.usersOnline.detail{/lang}</p>
{if USERS_ONLINE_RECORD}<p>{lang}wcf.user.usersOnline.record{/lang}</p>{/if}
</div>
{if USERS_ONLINE_ENABLE_LEGEND && $objects->getUsersOnlineMarkings()|count}
<dl class="plain inlineDataList usersOnlineLegend">
<dt>{lang}wcf.user.usersOnline.marking.legend{/lang}</dt>
<dd>
<ul class="inlineList commaSeparated">
{foreach from=$objects->getUsersOnlineMarkings() item=usersOnlineMarking}
<li>{@$usersOnlineMarking}</li>
{/foreach}
</ul>
</dd>
</dl>
</div>
{/if}
</section>
{/capture}
{capture assign='contentInteractionPagination'}
{pages print=true assign=pagesLinks controller='UsersOnlineList' link="pageNo=%d&sortField=$sortField&sortOrder=$sortOrder"}
{/capture}
{include file='header'}
{assign var=usersOnlineList value=''}
{assign var=usersOnline value=0}
{assign var=robotsOnlineList value=''}
{assign var=robotsOnline value=0}
{assign var=guestsOnlineList value=''}
{assign var=guestsOnline value=0}
{foreach from=$objects item=user}
{capture assign=locationData}
<p>
{if $user->getLocation()}{@$user->getLocation()}{else}{lang}wcf.user.usersOnline.location.unknown{/lang}{/if} <small class="separatorLeft">{@$user->lastActivityTime|time}</small>
</p>
{/capture}
{capture assign=sessionData}
<dl class="plain inlineDataList small">
<dt>{lang}wcf.user.usersOnline.ipAddress{/lang}</dt>
<dd title="{$user->getFormattedIPAddress()}">{@$user->getFormattedIPAddress()|ipSearch}</dd>
{if !$user->spiderID}
<dt>{lang}wcf.user.usersOnline.userAgent{/lang}</dt>
<dd title="{$user->userAgent}">{$user->getBrowser()|truncate:30}</dd>
{/if}
</dl>
{/if}
{/capture}
{if $user->userID}
{* member *}
{capture append=usersOnlineList}
<li>
<div class="box48">
<div class="containerHeadline">
<h3>{user object=$user}
{if MODULE_USER_RANK}
{if $user->getUserTitle()}
<span class="badge userTitleBadge{if $user->getRank() && $user->getRank()->cssClassName} {@$user->getRank()->cssClassName}{/if}">{$user->getUserTitle()}</span>
{/if}
{if $user->getRank() && $user->getRank()->rankImage}
<span class="userRankImage">{@$user->getRank()->getImage()}</span>
{/if}
{/if}
</h3>
{@$locationData}
</div>
{@$sessionData}
{include file='userInformationButtons'}
</div>
</div>
</li>
{/capture}
{assign var=usersOnline value=$usersOnline+1}
{elseif $user->spiderID}
{* search robot *}
{capture append=robotsOnlineList}
<li>
<div class="box48">
<div><img src="{$__wcf->getPath()}images/avatars/avatar-spider-default.svg" alt="" class="userAvatarImage" height="48" width="48"></div>
<h3>{if $user->getSpider()->spiderURL}<a {anchorAttributes url=$user->getSpider()->spiderURL}>{$user->getSpider()->spiderName}</a>{else}{$user->getSpider()->spiderName}{/if}</h3>
{@$locationData}
</div>
{@$sessionData}
</div>
</div>
</li>
{/capture}
{assign var=robotsOnline value=$robotsOnline+1}
{else}
{* unregistered *}
{capture append=guestsOnlineList}
<li>
<div class="box48">
<div><img src="{$__wcf->getPath()}images/avatars/avatar-default.svg" alt="" class="userAvatarImage" height="48" width="48"></div>
<h3>{lang}wcf.user.guest{/lang}</h3>
{@$locationData}
</div>
{@$sessionData}
</div>
</div>
</li>
{/capture}
{assign var=guestsOnline value=$guestsOnline+1}
{/if}
{/foreach}
{if $usersOnline}
<section class="section sectionContainerList">
<h2 class="sectionTitle">{lang}wcf.user.usersOnline.users{/lang}</h2>
<ol class="containerList userList">
{@$usersOnlineList}
</ol>
</section>
{/if}
{if $guestsOnline && USERS_ONLINE_SHOW_GUESTS}
<h2 class="sectionTitle">{lang}wcf.user.usersOnline.guests{/lang}</h2>
{@$guestsOnlineList}
</ol>
</section>
{/if}
{if $robotsOnline && USERS_ONLINE_SHOW_ROBOTS}
<h2 class="sectionTitle">{lang}wcf.user.usersOnline.robots{/lang}</h2>
{@$robotsOnlineList}
</ol>
</section>
{/if}
<footer class="contentFooter">
{hascontent}
<div class="paginationBottom">
{content}{@$pagesLinks}{/content}
</div>
{/hascontent}
{hascontent}
<nav class="contentFooterNavigation">
<ul>
{content}{event name='contentFooterNavigation'}{/content}
</ul>
</nav>
{/hascontent}
</footer>
<script data-relocate="true">
$(function() {
WCF.Language.addObject({
'wcf.user.button.follow': '{jslang}wcf.user.button.follow{/jslang}',
'wcf.user.button.unfollow': '{jslang}wcf.user.button.unfollow{/jslang}',
new WCF.User.Action.Follow($('.userList > li'));
</script>
{include file='footer'}
