Update: WoltLab Suite 5.4.8
    • WoltLab Suite 5.4.8
    How to Apply Updates
    • The import of blogs now supports cover photos. 5.4
    • (Non-functional changes for technical reasons only.) 5.4
    WoltLab Suite Calendar: Event Threads
    • Embedded objects in descriptions of file versions had not been loaded. 5.4
    • The mobile view of the thread list could display incorrect cached values for the thread starter. 5.4
    • User signatures were not displayed below messages. 5.4
    • Resolved an issue that caused an error when viewing the list of attachments. 5.4
    • Invision Community 4.x
      • Added support for the import of the blog and gallery. 5.4
      • Incorrect handling of URL placeholders in messages. 5.4
    • Resolved an issue that caused an incorrect report that the session was expired on form submit. 5.4
    • Resolved an issue that caused the setup to fail when using an unencrypted http connection. 5.4
    • Improved the message when encountering an invalid XSRF protection token. 5.4
    • Resolved a compatibility issue when running under PHP 8.1. 5.4
    • Fixed a visual artifact when the main menu starts overflowing. 5.4
    • Resolved an issue when using the ancient mysql extension instead of mysqlnd (MySQL Native Driver). 5.4
    • Form Builder: Resetting a form did not clear the values for ACL permissions. 5.4
    • Dev Tools: The standalone flag for instructions was not applied correctly. 5.4
    Quelle: https://www.woltlab.com/commun…date-woltlab-suite-5-4-8/
    Das ist eine Test Signatur
