Update: WoltLab Suite 5.4.9 / 5.3.15 / 5.2.16 / 3.1.24
    • WoltLab Suite 5.4.9
    • WoltLab Suite 5.3.15
    • WoltLab Suite 5.2.16
    • WoltLab Suite 3.1.24
    How to Apply Updates
    • Empty blogs are no longer listed in the sitemap. 5.4 5.3
    • A display error of the calendar weeks was corrected. 5.4
    • The license confirmation will now be prompted again after one day. 5.4
    • The checkbox for disabling/approving reviews when creating and editing files is no longer displayed when reviews are disabled. 5.4
    • Embedded objects in descriptions of file versions were not loaded. 5.3
    • When approving posts, the starting post stored in the thread is now updated correctly. 5.4 5.3
    • Merging deleted threads will no longer cause incorrect updates to the board statistics. 5.4
    • Reactions details of posts can now be viewed correctly in the article view when discussion topics are enabled. 5.4 5.3 5.2
    • vBulletin 5.x
      • The import of BCrypt passwords has been fixed.
    WoltLab Suite Core: WebAuthn
    • Updated some external libraries. 5.4
    • Tables were not always processed correctly when inserted into the editor. 5.4
    • The behavior of the editor after submitting a post was fixed for Opera Mobile. 5.4
    • Auto-completion, e.g. for usernames, sometimes displayed excluded or already selected entries. 5.4
    • Displaying different content types on one page no longer causes problems when quoting. 5.4
    • Deletion of content with reactions of deleted users could fail due to a bug in MySQL 8.x. A workaround for this error message has been integrated. 5.4
    • Rich embeds are no longer converted to signatures. 5.4
    • Timeouts when reading the response of the source server in ImageProxy and rich embeds no longer lead to an error message. 5.4
    • Added support for embedding private Vimeo videos. 5.4
    • An existing block of now unblockable users can now be unblocked in the user profile. 5.4
    • The new request for the confirmation code for an e-mail change is no longer incorrectly rejected with a message that the user is already activated. 5.4 5.3 5.2 3.1
    • When sending e-mails via PHP, e-mail headers are now also converted to "canonical" notation instead of being entirely lowercase. This avoids problems with email servers that insist on a certain spelling, contrary to the email standard. 5.4
    • The acpSimple template has been aligned between frontend and ACP. 5.4
    • The preview in the administration interface now works even if the article BBCode is used in the content. 5.4
    • The incorrect spacing at the bottom of the page when displaying full-screen dialogs (for example, the display of responding users) under iOS 15 is now suppressed. 5.4
    • The tooltip for links in the editor on small screens was sometimes positioned incorrectly. 5.4
    • When editing links in the editor sometimes the existing link was not edited. 5.4
    • Message editing options were positioned too far up on small screens. 5.4
    • The loading indicator for background requests ("AJAX") is now displayed correctly even after a failed request. 5.4 5.3 5.2 3.1
    • When signature images are scaled due to the maximum height setting, the aspect ratio is now preserved. 5.4
    • The names of authors in the listing of articles are no longer linked. In practice, the links were only accessible via the keyboard, because the entire space is a link to the article. 5.4
    • The display of code boxes inside citations was corrected. 5.4
    • Fixed a visual bug that became visible when not all items in the main menu can be displayed. 5.3
    • Form Builder: When resetting a form, the values for ACL permissions were not cleared. 5.3
    • For developers: Session::getDeviceIcon() is now deprecated. 5.4
    • For developers: The PHP-based DDL API now rejects indices with duplicate columns. 5.4
    • For developers: The PHP-based DDL API could reject valid changes as invalid under certain circumstances. 5.4
    • For developers: The UserFormField can now be initialized with IDs of non-existent users without causing an error message. This especially affects the processing of data where null is stored as userID. 5.4
    Quelle: https://www.woltlab.com/commun…4-9-5-3-15-5-2-16-3-1-24/
    Das ist eine Test Signatur
