    Quelle: https://pluginstore.woltlab.co…basic-core-light-edition/
    Quelle: https://www.woltlab.com/plugin…cketsystem-e-mail-import/
    Quelle: https://pluginstore.woltlab.co…cketsystem-e-mail-import/
    Quelle: https://www.woltlab.com/pluginstore/file/7077-minecraft-api/
    Quelle: https://pluginstore.woltlab.com/file/7077-minecraft-api/
    Quelle: https://www.woltlab.com/commun…s-and-new-extra-services/
    Quelle: https://www.woltlab.com/commun…nd-neue-zusatzleistungen/
    Quelle: https://community.woltlab.com/…nd-neue-zusatzleistungen/
    Quelle: https://www.woltlab.com/pluginstore/file/7075-bats/
    Quelle: https://pluginstore.woltlab.com/file/7075-bats/
    Quelle: https://www.woltlab.com/plugin…y-projekte-branding-free/
    Quelle: https://pluginstore.woltlab.co…y-projekte-branding-free/
    Quelle: https://www.woltlab.com/plugin…entwickler-shunting-yard/
    Quelle: https://pluginstore.woltlab.co…entwickler-shunting-yard/
    Quelle: VieCode Filebase Slider
    • WoltLab Suite 5.4.8
    How to Apply Updates
    • The import of blogs now supports cover photos. 5.4
    • (Non-functional changes for technical reasons only.) 5.4
    WoltLab Suite Calendar: Event Threads
    • Embedded objects in descriptions of file versions had not been loaded. 5.4
    • The mobile view of the thread list could display incorrect cached values for the thread starter. 5.4
    • User signatures were not displayed below messages. 5.4
    • Resolved an issue that caused an error when viewing the list of attachments. 5.4
    • Invision Community 4.x
      • Added support for the import of the blog and gallery. 5.4
      • Incorrect handling of URL placeholders in messages. 5.4
    • Resolved an issue that caused an incorrect report that the session was expired on form submit. 5.4
    • Resolved an issue that caused the setup to fail when using an unencrypted http connection. 5.4
    • Improved the message when encountering an invalid XSRF protection token. 5.4
    • Resolved a compatibility issue when running under PHP 8.1. 5.4
    • Fixed a visual artifact when the main menu starts overflowing. 5.4
    • Resolved an issue when using the ancient mysql extension instead of mysqlnd (MySQL Native Driver). 5.4
    • Form Builder: Resetting a form did not clear the values for ACL permissions. 5.4
    • Dev Tools: The standalone flag for instructions was not applied correctly. 5.4
    Quelle: https://www.woltlab.com/commun…date-woltlab-suite-5-4-8/
    • Der Import von Blogs unterstützt jetzt Titelbilder. 5.4
    • (Nicht-funktionale Änderungen aus rein technischen Gründen). 5.4
    • Eingebettete Objekte in Beschreibungen von Dateiversionen wurden nicht geladen. 5.4
    • Die mobile Ansicht der Themenliste konnte falsche zwischengespeicherte Werte für den Themenstarter anzeigen. 5.4
    • Die Signaturen von Benutzern wurden nicht unter Nachrichten angezeigt. 5.4
    • Es wurde ein Problem behoben, das bei der Anzeige der Liste der Dateianhänge einen Fehler verursachte. 5.4
      • Unterstützung für den Import von Blog und Galerie hinzugefügt. 5.4
      • Fehlerhafte Behandlung von URL-Platzhaltern in Nachrichten. 5.4
    • Es wurde ein Problem behoben, das zu der falschen Meldung führte, dass die Sitzung beim Absenden des Formulars abgelaufen sei. 5.4
    • Es wurde ein Problem behoben, das dazu führte, dass die Einrichtung bei Verwendung einer unverschlüsselten http-Verbindung fehlschlug. 5.4
    • Die Meldung beim Auftreten eines ungültigen XSRF-Schutz-Tokens wurde verbessert. 5.4
    • Es wurde ein Kompatibilitätsproblem bei der Ausführung unter PHP 8.1 behoben. 5.4
    • Es wurde ein visueller Fehler behoben, der sichtbar wurde, sobald nicht mehr alle Einträge im Hauptmenü angezeigt werden können. 5.4
    • Ein Problem bei der Verwendung der veralteten mysql-Erweiterung anstelle von mysqlnd (MySQL Native Driver) wurde behoben. 5.4
    • Form-Builder: Beim Zurücksetzen eines Formulars wurden die Werte für ACL-Berechtigungen nicht gelöscht. 5.4
    • Dev Tools: Die standalone-Flag für Anweisungen wurde nicht korrekt angewendet. 5.4
    Quelle: https://community.woltlab.com/…date-woltlab-suite-5-4-8/
