- WoltLab Suite 5.4.10
- WoltLab Suite 5.3.16
How to Apply Updates
- When removing images from an album, the visibility is now correctly reset. Images that are not stored in an album do not support the specification of a visibility and are generally visible to everyone. The visibilities of affected images will be corrected as part of the update. 5.4
WoltLab Suite Core: Conversation
- Drafts are now counted towards the number of conversations sent only when they are actually sent, not when they are created. 5.4
WoltLab Suite Core: WebAuthn
- Updated the bundled external libraries. 5.4
- Several errors that could lead to invalid HTML when editing lists have been fixed. 5.4
- Reliability of inserting tables into the editor, e.g. from Google Sheets, was improved. 5.4
- Language switching for articles and activated developer tools does not work correctly. 5.4
- Missing permission to delete profile title images no longer causes a JavaScript error. 5.4
- In the user search the additional columns could not be deselected completely. 5.4
- Removing entries in the access rights setting could cause that changes were not saved. 5.4
- Zero-width spaces are now truncated at the beginning and end of entries. 5.4
- Selecting suggestions for search terms sometimes triggered erroneously. 5.4
- Text selection in the editor on mobile devices is no longer recognized as a "click" and now works as expected. 5.4
- Fixed a bug where the style logo was deleted in the database but not in the file system, leaving orphaned files in the file system. 5.4
- Supplied favicons are now correctly applied during style import. 5.4
- When exporting styles, hidden files in the image folder are no longer exported. 5.4
- Failed connections for Google Fonts download during style import no longer lead to an error message. 5.4
- Defective attributes of BBCodes could cause an abort during processing. 5.4
- For developers: The parameters of the include() family are now correctly displayed in the stack trace of error messages. 5.4
- For developers: An incorrect database state comparison for the length of a field in the PHP DDL API was fixed. In particular, YearDatabaseTableColumn was affected. 5.4 5.3
Quelle: https://www.woltlab.com/commun…tlab-suite-5-4-10-5-3-16/
