Hallo, Besucher der Thread wurde 57 mal aufgerufen und enthält 0 Antworten
letzter Beitrag von Newsy am
Update: WoltLab Suite 5.2.1
  • Update: WoltLab Suite 5.2.1
    • WoltLab Suite 5.2.1
    Performing System Updates
    • The search for items matching one or more tags could raise an error under certain circumstances.
    • The list of user events raised an exception if no user id was provided.
    • The year view incorrectly defaulted to 2019 rather than the current year.
    • Invalid date ranges will no longer cause an error in the event overlap check.
    • Repeated events were affected by an incorrect calculation of the end date.
    • An incorrect number of purchased quantities was reported to customers of a file.
    • Approving a file attempted to remove non existent items in the moderation queue.
    • Rebuilding files and versions failed due to a pending query cursor.
    • Albums did not use the new masonry layout.
    • Disallowing attachments for users caused an incorrect validation error.
    • An implicit limit caused the list of received reactions to be cut off.
    • The link recognition in messages performed incorrect operations on the message.
    • Captions for media items used as article images did not support HTML.
    • The teaser image of articles had not been used on the article list.
    • Removed an unintentional gap after a user was mentioned in a message.
    • Improved the upgrade process from WoltLab Suite 3.1, all steps during the Core upgrade are now idempotent.
    • The owner group now has always access to all user groups as intended.
    • MySQL 8 suffered from a serious bug that caused incorrect reports of the key definitions. For MySQL 8 only, we'll now require MySQL 8.0.14 or newer.
    Quelle: https://community.woltlab.com/…date-woltlab-suite-5-2-1/
    Hallo Gast,
    gefällt dir der Thread, willst du was dazu schreiben,
    Dieses Thema enthält 0 weitere Beiträge, die nur für registrierte Benutzer sichtbar sind, bitte registriere dich oder melde dich an um diese lesen zu können.
