My Mood Icon Not Displaying
    WoltLab Suite Version
    6.0.x
    Plugin Version
    6.0.1
    When choosing "My Mood" Option for Working/Learning - the icon does not display
    In Firefox Browser it looks like this:
    In Chrome it looks like this:
    Greetz,
    DS
    DragonSmolt
    Wenn Sie die englische XML-Datei herunterladen und bearbeiten Working/Learning
    If you download English xml file and edit Working/Learning
    Now holidays are over, I'm just getting around to looking at this issue again, and wanted to give an update on it.
    Thank you tunhj1 for the tip about the xml file. Unfortunately I could not find the XML file (probably not looking in the proper place) but while exploring the issue here is what I noticed :
    The learning / working icon was not the only one not being displayed. The only icon that displayed correctly was the "Cool" option
    On the Front End on the forum in the User Profile Panel the options listed are:
    On the server in the directory icon ->image ->mood the contents there showed these files
    Using the "Inspect Option" in Firefox Browser, looked at the path to the image for each icon.
    The file names were in English - so far so good.
    However for the learning / working option it showed this: <img src="https://*******.com//icon/mood/learning / working.png" title="learning / working">
    I think the format of the file name may be the issue for the learning / working option.
    But for the other images it seemed to be a language / localisation issue
    Since I could not locate the XML file I tried this instead:
    Downloaded the Images found on the server that had German file names and Using Google Translate to match the names on the server, renamed each of them based on the names shown in the <img src> path
    Once this was done all the icons displayed correctly except the learning / working option.
    Greetz,
    DS
